| GR8GAZOO |
| Posted: Sep 21 2002, 03:34 AM |
I have ripped a DVD, and have used DVD2AVI. From there is virtual dub a program that will allow me to join the files into one continuous stream? If so, how exactly (step by step) do you use it? What shoud I tick, etc. I just want to save to my hard drive and not burn a VCD or XVCD. Do I make sense? |
| Posted: Sep 21 2002, 04:37 AM |
Don't be so hasty to tell people you have ripped a DVD! Let's just say you've obtained a DVD rip from an unknown source, OK?
I've never used the (probably illegal) program you mentioned. What files did the program create that you would need to join them? I assume from the name of the program that they are AVI files, therefore:
1) Start VirtualDub 2) File->Open video file (choose the first AVI) 3) File->Append AVI segment (choose the second AVI) 4) Repeat step 3 for each additional segment 5) Choose Video->Direct stream copy 6) File->Save old format AVI (create a new AVI)
If step 3 fails, the AVI files are incompatible and your problem becomes much more complicated.
| ChristianHJW |
| Posted: Sep 22 2002, 07:58 AM |
I assume you visit http://www.doom9.org , goto download section and get 'TheGordianKnot' from there.
Its based on Vitualdub, does the frameserving etc. via AVISynth and is very comfortable and flexible also ....
