Status Window
boogerlad
Posted: Jun 5 2014, 10:07 PM
How do I keep the status window open after the encoding finishes? I'm trying to benchmark lagarith, using a sequence of png images that I input into VirtualDub. I'm also open to other suggestions not using VirtualDub at all.
Posted: Jun 6 2014, 04:59 AM
You can't
You can use the job control and queue a batch operation though
That shows start and end times of a job in the dialog (and you can reset the job to repeat it)
Someone else needed more accuracy for the duration than the display shows, so I wrote a program for them at
https://dl.dropboxusercontent.com/u/1702491...ff/JobTimes.zip
1 replies since Jun 5 2014, 10:07 PM Track this topic | Email this topic | Print this topic
