| eboul |
| Posted: May 14 2014, 01:58 PM |
I had added some audio to a video last week (several reboots since then), but now every video I edit has this audio added to it. I have been playing with my audio settings but no luck. I know that's not much information, please tell me what you need to know and I will tell you. I have tried playing with "no audio" and "direct stream copy" which I thought would do the trick but no luck there. Honestly I'm a bit baffled as to why both selections can be made at the same time shouldn't no audio mean no audio? Searched a bunch but just came up with answers on how to extract audio which is not my problem. |
| Abrazo |
| Posted: May 14 2014, 05:21 PM |
The only way I know to add other video via VirtualDub, is by going via the Audio-menu, Audio from other file ... Maybe you did save it in your processing settings ? (File > Save processing settings...)
If this is not the case, then it is a very strange phenomenon.
Maybe you can delete all VirtualDub user-settings (while VirtualDub is closed) in Windows Registry and start over again. > HKEY_CURRENT_USER\Software\VirtualDub.org\VirtualDub |
