Dnr Acting Strangely, Filter works, but won't let me configure
boobounder
Posted: Jan 22 2014, 01:35 AM
Several people have advised that I use the DNR (Dynamic Noise Reduction) filter.
I added it, with the default parameter of 12, and I can tell (from before and afters) that it works.
But ... when I click "Configure" to adjust that value ... the small dialog window opens and immediately closes before I can adjust the value.
Any ideas? This is the only filter I've tried that has this problem.
Posted: Jan 22 2014, 05:45 AM
Is it either of these filters ?
http://www.shdon.com/vid/dnr
The dialog from those show fine here
Posted: Jan 22 2014, 08:30 PM
@dloneranger
For your information:
The dialogbox shows fine in VirtualDub 1.9.11, but not in 1.10.4.x, nor in 1.10.5.x.
And this as well for the Original (dnr1.vdf) as for the MMX (dnr2.vdf) version of the DNR filter.
We can see that Avery Lee (alias phaeron) was also involved ... so maybe he can help about this ?
Posted: Jan 22 2014, 08:42 PM
That'd explain it then
Always helps when there's some actually useful info
boobounder
Posted: Jan 23 2014, 06:40 AM
dloneranger: Yes ... those are the two filters I'm having trouble with. Sorry I wasn't clear enough.
Abrazo: I am running 1.10.4
But I'm confused. The tone of the last 2 replies makes me think this might be a feature and not a bug. Which is it?
Posted: Jan 23 2014, 10:36 AM
Something happened in the latest versions of the virtualdub that stops it working properly
a bug reports been added to the developers list
meowmeow
Posted: Jan 23 2014, 10:13 PM
filter's open source so maybe recompiling it with newer VD libraries will help?
is it better than smoother / temporal smoother?
evropej
Posted: Jan 23 2014, 10:15 PM
I am not a big fan of this filter It only works well if there are no fast moving objects. Temporal artifacts are generally created by moving objects.
Posted: Jan 26 2014, 12:00 AM
It's a bug in the filter -- it has a subtle bug in its dialog code that causes it to fail when XP+ visual styles are enabled on the host application. Posted a fixed version a while back:
http://www.virtualdub.org/downloads/dnr2-v...-vstylesfix.zip
http://www.virtualdub.org/downloads/dnr2-v...ylesfix-src.zip
boobounder
Posted: Jan 26 2014, 08:30 AM
Thanks. Works fine. Sorry I missed it before.
9 replies since Jan 22 2014, 01:35 AM Track this topic | Email this topic | Print this topic
