Job List, job list not saved updated on exit
gzu
Posted: Jan 2 2014, 11:36 PM
I recently updated to 1.10.4 stable and now my joblist is not updated when I exit VirtualDub (I assume it is updated on exit).
So new jobs appear to be added to the queued job list and are processed normally, next time I start VD then the new jobs are no longer at the end of the list.
Have I missed something? I can manually save the job list, but I prefer the old behaviour.
Any tips and suggestions welcome.
Thanks,
GZU
Posted: Jan 3 2014, 05:53 AM
The jobs file should be saved a second or two after it's added to the queue (or on exit if it's not already saved)
Just tested with 1.10.4 and it worked as expected here
There is a new option that might affect you though
In options->startup there's a choice to save in the same folder as virtualdub or in your user profile
You could try changing that and see if it's ok
gzu
Posted: Jan 7 2014, 04:08 AM
Thanks for the suggestions.
I thought I had already tried changing that option and it didn't work.
I've changed it to "user profile" and it now looks as though it is saving the list OK now.
Thanks again,
GZU
2 replies since Jan 2 2014, 11:36 PM Track this topic | Email this topic | Print this topic
