How To Get Virtualdub To Capture?, Question about usage.
forrie
Posted: Sep 17 2002, 03:52 PM
I have the Osprey 220 capture board, and am able to use their VidCap32 application without problems. I was referred to VirtualDub, and loaded it into my system - however, I cannot find where you set it to capture frames.
The helpfile shows an older version with "Capture" in the menu area; but that isn't present in the latest version... I see you can "Capture AVI" from the File menu, but this seems to gather frames, not still shots.
Specifically, I'm interested in still-frame capture (at the highest resolution my board will support).
Thanks...
Ciler
Posted: Sep 18 2002, 06:40 AM
Hello,
well, Virtual Dub was basically designed to capture movies (actually animes tongue.gif), not still-frames. Maybe you can try to caputre a short time of video, then extract the frame you want.
1 replies since Sep 17 2002, 03:52 PM Track this topic | Email this topic | Print this topic
