| jahpal |
| Posted: Nov 13 2013, 01:45 AM |
i load the file but when i press play message says: no audio decompressor could be found to decompress the source audio format (source format tag: 0161) . now i know im missing the ACM codec , but i try your links they are dead , by the way im on windows 7 ultimate 64 bit . THANK YOU... Can anybody Help Me With This? i fallow your advice remove the WMV and BAAnGGG it Worked. thank you very much... give thanks |
| Posted: Nov 13 2013, 06:14 AM |
Try using the DirectShow or FFMPeg plugin http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
Extract the zips contents to the plugins32 folder Start virtualdub When in the "Open video file" dialogbox of VirtualDub, first select the file, then at files of type : select FFMPegor DirectShow Finally click "Open".
If you remove the wmv plugin, then one of those two should be used automatically
