Shell Command: Convert List Of .jpg To Mpeg Or Avi, .bat file comman conversion JPG to AVI
mpo
Posted: Sep 6 2013, 03:59 PM
I understand the functionality of converting jpg to avi (or other format) is already there.
Would there be an option to call this functionality from a .bat file?
I have folders of 500+ jpg images generated on a regular basis and I need them to be converted into any common video format. I do not have any special quality or frame rate requirements. Any help appreciated. Thank you.
~mpo
malky
Posted: Sep 6 2013, 04:22 PM
You could simply rename the files sequentially, and as long as they are the same resolution, opening the first in sequence will automatically append the rest.
http://www.virtualdub.org/blog/pivot/entry.php?id=34
mpo
Posted: Sep 6 2013, 04:55 PM
...yes, my jpg files are all the same size, format and are sequentially numbered i.e.: 001.jpg, 002.jpg, 003.jpg..... etc. The feature works fine from the application drop-down menu but how can I execute this in command line or through .bat file?
Thank you.
~mpo
raffriff42
Posted: Sep 6 2013, 06:39 PM
It's doable. You create a Virtualdub script::
  • Set up V-dub filters & compression as desired.
  • File, Save Settings.
  • Open settings file in text editor.
  • Add these lines to the end of your settings file:
    VirtualDub.SaveAVI(%1);
    VirtualDub.Close();
Save as *.vcf. It will look like this example.
Then at a command prompt:
"<path\to\vdub.exe>" /x /s "<path\to\script.vcf>"
mpo
Posted: Sep 6 2013, 08:49 PM
..excellent! thank you, I will try that.
malky
Posted: Sep 6 2013, 11:41 PM
FWIW, this bat file works.
:: verify paths and filenames.
:: Image jpeg files are named four digits, e.g 0001.jpg
:: assumes that XviD codec is installed.
:: output is 000.avi
:: running 'vdub.exe' exits when script finished, 'VirtualDub.exe' waits for user input to exit VirtualDub screen.
:: this bat file placed in same folder as source images.
set vdub="c:\program files\virtualdub\vdub.exe"
for /f "delims=" %%a in (
'dir *0001.jpg /a:-d /o:n /b'
) do call :next "%%a"
GOTO:EOF
:next
set "name=%~n1"
set "name=%name:~0,-1%"
echo processing "%name%.avi"
>vdub.vcf echo VirtualDub.video.SetMode(3);
>vdub.vcf echo VirtualDub.video.SetCompression();
>vdub.vcf echo VirtualDub.video.SetCompression(0x32317679,0,10000,0);
>>vdub.vcf echo VirtualDub.Open("%name%1.jpg",0,0);
>>vdub.vcf echo VirtualDub.Append("%name%2.jpg");
if exist "%name%3.jpg" >>vdub.vcf echo VirtualDub.Append("%name%3.jpg");
>>vdub.vcf echo VirtualDub.SaveAVI("%name%.avi");
>>vdub.vcf echo VirtualDub.Close();
%vdub% /s vdub.vcf >nul
del vdub.vcf
5 replies since Sep 6 2013, 03:59 PM Track this topic | Email this topic | Print this topic
