| MikeAtHome |
| Posted: Jun 30 2013, 01:48 PM |
Hi. I'm running the 64-bit version of the latest release of the VirtualDub. I got Gunnar Thalin's deinterlacing filters from the WWW and put the .vdf file in the plugins64 folder. But when I try to add a filter in VirtualDub, those filters are not listed along with the standard default filters.
So for debugging, I did the same thing with the 32-bit version of VirtualDub and everything worked.
My questions is how can I obtain 64-bit versions of common filters, like Gunnar Thalin's, or can I make those 32-bit filters work with 64-bit VirtualDub? |
| Posted: Jun 30 2013, 01:59 PM |
Only 64bit filters work in 64bit virtualdub You can only get a 64bit version if somebody actually made one
