Adjsut Last And First Frame Exposures To Match
MJSfoto1956
Posted: Apr 25 2013, 01:21 AM
So I'm trying to append AVI_#2 to AVI_#1 but the last exposure on AVI_#1 is slightly darker than the first exposure of AVI_#2.
Is there anyway to change the exposures so that the two adjacent frames look like they belong together? Ideal would be some way of "ramping" the exposure say of AVI_#1 to start at zero compensation on its first frame then gradually ramp to slightly lighter on the last frame. And similarly, the first frame of AVI_#2 would be slightly lighter, ramping gradually to zero compensation at its last frame.
Any ideas?
Cheers
M
Posted: Apr 25 2013, 05:08 AM
Add any of the brightness/contrast/exposure/levels type filters - then after altering the brightness etc, select the filter in the list and click the blend button, and OK out of the filter list
Back on the main virtualdub screen, goto the view menu and click 'curve editor'
With that, you can draw a line that represents how much % effect the filter has over time
example video showing how it works
https://dl.dropboxusercontent.com/u/1702491...CurveEditor.avi
MJSfoto1956
Posted: Apr 26 2013, 02:55 AM
wow. thanks. that did the trick!
2 replies since Apr 25 2013, 01:21 AM Track this topic | Email this topic | Print this topic
