| alastina |
| Posted: Mar 18 2013, 10:34 AM |
Hello,
I would like to make a movie out of a multitude of camera images (in jpg), something like a memomotion study. I have found a very good instruction in the Internet. After running the program, the first step should be to add the images by drag and drop. My instruction says to open the first image of the folder, as Virtual Dub will add all the following images by itself. I have tried that several times, but Virtual Dub doesn't open anything, not even the first image! I can't find different ways to open the images, either.
I am very grateful for your replies....
alastina |
| malky |
| Posted: Mar 18 2013, 12:54 PM |
Are the files sequentially numbered and the same resolution? Run VirtualDub and drag the first file into the window.
| alastina |
| Posted: Mar 18 2013, 05:11 PM |
Thanks a lot, but I've found the mistake myself....I didn't run the proper program exe...I used the aux setup file instead of Virtual DubMod file. At first sight, I didn't note any difference. It's working now, juhu! |
