| mattad |
| Posted: Aug 3 2012, 10:03 AM |
Ok, if I want to see/edit videos with AC3 in VD I have to install the necessary AC3 codec.
However from my point of view there are two different way of AC3 installation/usage:
1.) Use the AC3 VD plugin from here: http://fcchandler.home.comcast.net/~fcchan.../AC3/index.html or 2.) Use the AC3 ACM codec from here: http://www.free-codecs.com/AC-3_ACM_Decomp...or_download.htm
So whats the difference (between plugin and ACM)?
Are both ways equivalent regarding VD?
Matt |
| Placio74 |
| Posted: Aug 3 2012, 01:50 PM |
VideoAudio
AC3 input plugin is suitable only to add audio from external .ac3 file (through audio from other file... option). This plugin doesn't contain a decoder.
AC3 ACM codec it's of course ACM codec to decoding/encoding AC-3 audio - can be used in any application that uses ACM framework.
