| Bad_Karma |
| Posted: Jul 23 2012, 01:34 PM |
I receive the above error every time I try to open a DivX5 encoded avi in VirtualDub 1.9.11 (AMD64) on Windows 7 64bit.
I have installed DivX Plus v8.2.3 which includes the DivX 6.9.2 codec.
What do I do wrong? |
| malky |
| Posted: Jul 23 2012, 03:36 PM |
Try: File > Open video file Check the box for 'Ask for extended options..'
Check boxes 'Force video format...' and 'Force video codec...' and type:divx in both |
| Posted: Jul 23 2012, 03:54 PM |
The problem is that divx is 32bit and you're using a 64bit program You could install the 64bit version of ffdshow or xvid to decode divx, or just use the 32bit version of virtualdub instead The 32bit version of virtualdub runs fine on 62bit windows, and has less problems with missing codecs, plus, more add on filters work with it
| Bad_Karma |
Posted: Jul 23 2012, 07:40 PM |
Thanks very much for your replies! |
