| derfaust |
| Posted: Sep 14 2002, 09:31 PM |
ok.....i have been using virtualdub for a little over a year...never a problem till this..... i have been having issues with audio sync when coverting MPEGS to AVIs...
when i load an MPEG into virtualdub(i am using the latest release) and then convert it to an AVI the audio is way out of sync...it will not even preview right...
not sure what i am doing wrong.....i think it might have something to do with the frame rate...but i dont know why it would be different....PLEASE HELP......THIS IS DRIVING ME CRAZY!!!!
the HUGE mpegs are in perfect sync when viewed, but i want to be able to turn them into AVIs......saving valuable space
is there a way to make the two stick together like glue?
| Neo Neko |
| Posted: Sep 14 2002, 11:18 PM |
VirtualdubMod Alpha tester
Virtualdubs MPEG parser works. But it has quirks. It seems not to know what to do with accidentaly or purposefully dropped frames. Instead of displaying the last frame over again it jumps to the next non-dropped frame.
This is a bit convoluted, but it works. If there is no delay in the audio in the MPEG you can open the MPEG in Virtualdub and use the File->Save Wav feature to extract the audio. Now assuming you have avisynth installed create an avi synth script with the line directshowsource("my.mpg") inside. You could also add in the audio there as well. But we will do that in Virtualdub instead for now. Open the AVS file in virtualdub. Under the audio menu select WAV source and then the WAV we saved. Configure your settings and then go. Assuming we are dealing with something as tame as dropped frames this will fix it. As instead of using Vdubs MPEG parser we are using the directshow one. |
| derfaust |
| Posted: Sep 15 2002, 08:02 AM |
i see....i will try.... but i only understood like half of it....i just have never messed with avisynth....but i like to learn new things so......... ....
but if you could give me a better/more detailed explanation that would be cool too....
i really appriciate your help....and any more information would rule...
danke, derfaust |
| derfaust |
| Posted: Sep 15 2002, 09:08 AM |
well i tried it....
i made a script file with the line directshowsource("C:\Documents and Settings\XLderfaust\Desktop\New Folder\Noname02.mpg")..
which is the location... that is the only line i added in there...
the file was still way out of sync..... the original MPEGs are in total sync...from start to finish... am i using avisynth wrong?...it did open the video...
if you could help me set up a script that would be cool....i understand what it does....i just need to see a script for what i need...then i can figure out what does what(take it apart)....thanks....again
| derfaust |
| Posted: Sep 16 2002, 03:07 AM |
well....i found a way to make it work....i used FlaskMPEG....and was able to encode it to DivX without loss of audio sync....then i used virtual dub to finish it up....
so cool.....but i would like to learn more about avisynth...so let me know... |
