Modify Framerate & Decimate In A Console Command
RedTheHunter
Posted: Jan 26 2012, 05:13 PM
Hello everybody,
First at all, let me explain the situation.
I'm working on a project involving video recording. Once the record is done, the result seems twice laggy than the normal.
Looking deeper in this video, I figured out that duplicate frames (or dropped) are present in the .avi. Each keyframe involve a [D] frame right after it.
During the time I'm looking for the error, I use VirtualDub. I can resolve the problem by double the frame rate and decimate the frames by 2.
The question is : How could I do the same, using the vdub.exe (console application) and a script? I'm looking on the Internet and the UserGuide and I can't find my solution.
Thanks you, RedTheHunter
RedTheHunter
  Posted: Mar 29 2012, 08:17 AM
While I was looking for something else, I finally found out how to do that.
VirtualDub.Open(sInput,0,0);
VirtualDub.video.SetFrameRate2(60,1,2);
VirtualDub.SaveAVI(sOutput);
VirtualDub.Close();
The 60 value correspond to the double framerate, 1 the index and 2 the decimate factor.
At least, if someone is in trouble, he could read that.
Thanks you for the software & thanks Dubman
RedTheHunter
P.S. : The scripting tutorial is quite a mess. I think it would be efficient to add examples in it.
1 replies since Jan 26 2012, 05:13 PM Track this topic | Email this topic | Print this topic
