Histogram Display During Playback
ecokid
Posted: Nov 30 2011, 08:25 AM
Hi Again
I look through a lot of video with differing lighting. It would be great if you could see a frame-by-frame histogram of the current frame on screen.
In fact, thinkig about it if there was a 'convert video to histogram filter, I could preview both the input (avi) and output (histogram) windows.
Is this already a feature that I can't find or is it too crazy for general appeal?
Must drink more coffee.
Thanks
Steve
ecokid
Posted: Dec 12 2011, 03:53 PM
Gosh no replies. Guess it's too crazy an idea then! I would like to correct a video for lighting changes and a histo would be very useful but I guess I'll have to look elsewhere for this feature :-)
Cheers
Steve
ale5000
Posted: Dec 12 2011, 04:10 PM
I don't know but there are a lot of video filters for VirtualDub for almost everything.
Try to find them on Google.
New VirtualDub forum
russell_t
Posted: Dec 12 2011, 04:34 PM
Avisynth has a histogram filter that might be useful to you:
http://avisynth.org/mediawiki/Histogram
ecokid
Posted: Dec 13 2011, 06:14 PM
Thanks both for your replies. I did spend quite a lot of time searching for this feature, but couldn't find it. I don;t think there's any 'display histogram during playback' filter. Could be wrong though :-)
I've glanced at avisynth before but been too stingy to invest the time in learning it - guess I'll have to bit the bullet.
Russel_t thanks for the link - that is EXACTLY what I want. Is there a noobs guide to using avisynth with vdub? or is that included in the download?
Onward and upward....
Steve
russell_t
Posted: Dec 13 2011, 07:21 PM
QUOTE (ecokid @ Dec 13 2011, 06:14 PM)
You can download Avisynth from this link:
http://sourceforge.net/projects/avisynth2/
Run the downloaded exe file to install Avisynth.
Open a text editor such as notepad and create a script such as:
avisource("your_filename.avi")
histogram(mode=" ")
In the first line, replace the your_filename text above with the avi file you wish to open.
In the second line, enter the histogram mode of your choice, based on the information from the wiki page linked above.
For path / scripting simplicity, save the file in the same folder as your avi file; give it a filename of your choice and use .avs (rather than .txt) as the filename extension.
Open (or drag-and-drop) this .avs file in VirtualDub.
Hope that helps.
ecokid
Posted: Dec 13 2011, 09:24 PM
Hi Russel
That helps loads thanks! I'll download it, follow your excellent instructions and have a play. I bet all the bells and whistles I need are in avisynth.
Thanks again
Steve
6 replies since Nov 30 2011, 08:25 AM Track this topic | Email this topic | Print this topic
