Can Not Open Any Avi Files In Virtualbub
jdubious
Posted: Sep 13 2002, 08:44 PM
All the AVI Files I try to open in VirtualDub give me this error:
Couldn't locate decompressor for format MP43
Can anyone help with this...thanks for all your help
Neo Neko
Posted: Sep 14 2002, 04:42 AM
VirtualdubMod Alpha tester
doom9.org has a fourcc changer. Change it from MP43 to Divx. Or you can use Vdub's hex editor and go in there manually and do that.
ChristianHJW
Posted: Sep 14 2002, 08:27 PM
hehe,
what other advice could you expect from a real M$ hater .. lol Neo !!
Install Windows Mediaplayer 7 ( but continue to use goold old 6.4 after that, search for mplayer2.exe on your c-drive ) or Windows Mediaencoder. The FourCC code 'mp43' is for M$ MPEG4V3 video, and you dont have this codec installed it seems, its coming with WMP 7.
Neo Neko
Posted: Sep 14 2002, 11:28 PM
MSMPEG4v3 is one of the locked versions and is not supposed to exist outside ASF/WMV. Sometimes even installing the MS codecs with WMP does not fix the problem. MSMPEG4v2&3 are Divx3.11. Actually it is the other way around. But you get the gist. Just look at the fourcc in a divx3 or 4 or 5 avi and change the ones in the problem AVI to match. Divx3 or 4 or 5 can and will then play the file with no qualms about it being in an AVI. It has little to do with MS being evil and more to do with a near sure fire way to get someones screwed up encode to work. wink.gif
jdubious
Posted: Sep 16 2002, 07:43 PM
Thanks Guys for your help....all your suggestions worked...I really appreciate it. THink you guys can help me out with one more error. Its the same message but except for when you load the AVI, it gives an error th
at it could not locatedecompressor for format "DX50".
Neo Neko
Posted: Sep 16 2002, 08:46 PM
Do you have Divx 5 installed?
jdubious
Posted: Sep 17 2002, 04:12 PM
I loaded the Nimo Codec pack, which I think have Divx 5. Should I just install the Divx 5 anyway. Thanks
6 replies since Sep 13 2002, 08:44 PM Track this topic | Email this topic | Print this topic
