Job Control Audio Error, Multiple Videos Compression Error
RedneckChamp
Posted: Jun 26 2011, 09:25 PM
Whenever I use Que Batch to get a lot of videos compressed at once I only get an error when I go to Job Control to start it. Here are the steps I take for my video compression.
1.) After selecting the compression that I want, I go to Que Batch>Batch Wizard.
2.) There I drag all the video clips I want to be compressed.
3.) Then I tell it to Re-Save as AVI and then hit OK.
4.) Afterwards I hit F4 or go to Job Control and tell it to start the process but get immediate errors all the way down the list.
Here is the error I get.
Error initializing audio stream compression:
The audio codec cannot compress the source audio to the desired format.
Check that the sampling rate and number of channels in the source is compatible with the selected compressed audio format.
Asked the same question in the Advanced Video Precessing Forum here: http://forums.virtualdub.org/index.php?act...=ST&f=5&t=20169
Thanks for any help!
-SPM-Mad
Posted: Jul 2 2011, 01:30 AM
Well, the error message is pretty clear, or?
You are trying to process audio and it is not compatible for some of your source files. You can set audio -> full progressing mode, then 'convert' to change it to a format your desired codec supports and select this one under compression.
Then it should work.
Greetings
-mad-
1 replies since Jun 26 2011, 09:25 PM Track this topic | Email this topic | Print this topic
