Damaged Avi File - Rekeyed Index
markmarques
  Posted: Aug 23 2010, 09:25 PM
I am using VDub almost for a decade now ...
Using the VDub 1.9.9 build 32817 ...
But recently I get this "strange" problem ...
I am trying to save a damage AVI but got thsi strange results :
File 733.501.440 bytes XVID codec
If I try to open it without the advanced options I get 921 frames ( 00:30 min) ...
With these errors:
[!] AVI: Index not found or damaged -- reconstructing via file scan.
[!] AVI: Invalid chunk detected at 7771996. Enabling aggressive recovery mode.
[!] AVI: Keyframe flag reconstruction was not specified in open options and
the video stream is not a known keyframe-only type. Seeking in the video
stream may be extremely slow.
[!] AVI: Variable bitrate (VBR) audio detected. VBR audio in AVI is
non-standard and you may encounter sync errors up to 69ms when attempting
to extract WAV files or playing in some players. If this is a problem, use
Full Processing mode is recommended to decompress or recompress the audio.
(This warning can be disabled in Options, Preferences, AVI. bitrate: 125.9
± 16.0 kbps)
Opening with the "Advanced options" activating : Forcing re-derive keyframe flags +
Opening AVIFile in compatibility mode I get:
± 16.0 kbps)
but this time I get 98087 frames ...
If I try to go past the "921" frame I get : Error damaged 921 frame ...
Also in the Input pane I get the last good keyframe (921) ....
If I try to "scan Video stream for errors" I get a new modal window that starting from 0 to 98087 ...
Starting ok bu stops at 916 frame ...
At the status bar I get :
97166 frames masked (0 frames bad, 97166 frames good but undecodable)
What else can I do to recover the data ?
Posted: Aug 23 2010, 09:55 PM
You could try DivFix++ http://divfixpp.sourceforge.net/
With the amount of damage that file has, you'll be lucky if it works
markmarques
Posted: Aug 24 2010, 08:02 AM
I have tried DivFix with no success...
It simply reads and identify the file and gives an empty "Bad frame Report" ....
I thought that VDub would be a better tool for this job...
Meanwhile I have tried "old" AVIMedic that gave me a small graphic with the position and number of the errors ...
Even giving some info regarding "patches" but due to the lack of documentation I do not know how to proceed further ...
VDub has an Hex Editor and I tried to check the data manually but to no avail ... sad.gif
Any more ideas ?
2 replies since Aug 23 2010, 09:25 PM Track this topic | Email this topic | Print this topic
