| cruising60 |
Posted: Sep 10 2002, 08:57 PM |
I have 3 avi files with all the same characterestics. I would like to make them into one avi file with the same amount of hard drive space now being used for the 3 files. Can someone tell me how I can do this? Thanks |
| Neo Neko |
Posted: Sep 10 2002, 11:29 PM |
VirtualdubMod Alpha tester
Open the first in Virtualdub. Then under the file menu select append and then the next chunk. Repeat the append till there are no more cunks. Set video and audio for direct stream copy and save yer new AVI. |
| cruising60 |
| Posted: Sep 11 2002, 02:40 PM |
Many thanks Neo. I had spent hours trying different things to append the two files and none of them worked. It would take me hours just to save them and view the results. I did not use the direct stream copy feature. Once I did that everything worked perfectly and saving the file took seconds instead of an hour. thanks again. |
