Removing Blue Colour Cast
Argonaut
Posted: Aug 27 2009, 03:41 PM
I take underwater video clips .. these typically have a severe Blue Colour cast (due to water filterring out the Red)
I asked here how to remove it (used to doing this in photoshop on stills)
Reply was to use Gradation Curves Filter
I have downloaded that and dropped the vdf file into Pulgins folder, and also put the 'amp' files in same folder.
I'm just having difficulties in how to use it.
I open a video clip ... go to video/filters
select Graduation Curves
It opens the control panel ..... at this point I may be going wrong.
I then import "Red+amp file.
What do I do then, do I select Red ch from RGB ?
When I select 'preview' it does not show any change ?
I have also tried the "blue-" amp file as well .... same thing.
... also on the authors tutorial site http://members.chello.at/nagiller/vdub/tut...l/tutorial.html
It shows that when you use thge Blue- amp file a curve that does not look like the curve I get when I import teh amp file ?
Guess I'm missing a step.
Anybody know what I should do .... or is there an alternative filter I should be using ?
0 replies since Aug 27 2009, 03:41 PM Track this topic | Email this topic | Print this topic
