| marsias |
| Posted: Oct 5 2005, 07:15 AM |
Hello.
Is the a way to tell VD to start up with my processing Settings, which i had save??
I don't wont to load separately always my settings.
thanks. |
| Posted: Oct 5 2005, 07:24 AM |
Save your configuration, then create a shortcut to VirtualDub.exe with the following added to the target line:
| CODE | | /s <config filename> |
This will cause the configuration to be loaded on startup. |
