Good Codecs For Virtualdub?
play32
Posted: Jun 21 2005, 02:53 PM
OK, I'm currently using ffdshow as it's the only one that could open all my avis with no trouble at all and the video quality is very good. But I can't open any file with VirtualDub, I get the following message:
"Couldn't locate decompressor for format 'XVID' (unknown)
VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
Where can I get such codecs?
Thanks.
stephanV
Posted: Jun 21 2005, 03:00 PM
usually a VFW component comes with ffdshow, so you can use that. If you are sure you installed the VFW component, go to start --> programs --> ffdshow --> VFW configuration and enable it from there.
useful links:
mrjwolf
Posted: Jun 21 2005, 07:52 PM
hello!
sorry if this is a silly question from a noobie but how exactly do you enable vfw in ffdshow
thanks in advance for any help from a confused and new user of virtual dub!!!!
mrjwolf
stephanV
Posted: Jun 21 2005, 08:03 PM
can you go here: windows start button --> programs --> ffdshow --> VFW configuration ?
useful links:
mrjwolf
Posted: Jun 21 2005, 08:09 PM
yep, got that far but am then blinded by what settings to change etc
mrjwolf
Posted: Jun 21 2005, 08:15 PM
Panic over!
after engaging brain and installing gordian knot codecs virtual dub now works like a dream!!!!!!!!!!!!!
many thanks again stephan v for trying to sort it
mrjwolf
Woodpecker
Posted: Aug 15 2005, 09:42 AM
Hello!
Just like mrjwolf I am wondering how EXACTLY you do you enable vfw in ffdshow.
I have version 20050803 of ffdshow an verision 1.9 of Gordian Knot Codec Pack.
Thanks
stephanV
Posted: Aug 15 2005, 10:17 AM
The VFW component is installed by default by that version of ffdshow. You can configure the settings in the place where i pointed at. (choose the decoder tab)
useful links:
Woodpecker
Posted: Aug 15 2005, 12:04 PM
Ok, I see. Now I think that I have another problem, but maybe anyone her can help me..
When I choose "Save as AVI" following message appear: user posted image
This message appear when I shall save a 2 Pass - 1st pass project.
What can my new broblem be?
Thanks, Woodpecker
stephanV
Posted: Aug 15 2005, 12:33 PM
could be any numbers of things, invalid resolution maybe?
if you want a better answer: give more (=all) info.
useful links:
Woodpecker
Posted: Aug 15 2005, 03:45 PM
For a time ago I found VFW configuration below ffdshow in the Start menu, but when I try to klick on it a error message appeard. I have now uninstalld ffdshow and installd it again.
When I installd ffdshow appeard any error message who say that it wasnīt possible to overwrite a stated file or anything like that..
Now after this, I canīt find VFW configuration on the place I do before.
Is it ffdshow I shall write about or shall I write about VirtualDub?
Thanks, Woodpecker
stephanV
Posted: Aug 15 2005, 04:36 PM
im confused now... you already had vfw acces in VirtualDub, but not anymore now?
useful links:
Woodpecker
Posted: Aug 15 2005, 09:11 PM
Im actually confused to.. I had just now not the possibility to change any settings under windows start button --> programs --> ffdshow --> VFW configuration . I can go through the three first steps but the fourth step, "VFW configuration", doesnīt exist in my meny.
The fourth step existed before I reinstall ffdshow but now it doesnīt.
Just now I donīt know if VFW is set to enable, can I control that anywhere?
LPrince
Posted: Aug 16 2005, 01:00 AM
Hi!
I got a couple of questions about DivX 6.
What is the difference between shaping and masking psychovisual enhancement?
During the first pass which compression/quality mode should I use?
Is there any reason to use quarter pixels, since you can't use any high compression modes when that's enabled?
stephanV
Posted: Aug 16 2005, 06:48 AM
QUOTE (Woodpecker @ Aug 15 2005, 11:11 PM)
It should be an option in the installer...
No idea, you could read the DivX guide about it.
Balanced is ok.
Nope, no reason at all.
useful links:
16 replies since Jun 21 2005, 02:53 PM Track this topic | Email this topic | Print this topic
Pages: (2) [1] 2
