Help! Audio Extraction..., TCM Encodes...
TheAsylum
Posted: Feb 18 2005, 10:44 AM
Hi People,
I'm having real problems with converting an AVI file into an SVCD. It's the latest episode of Desperate Housewives, a TCM encode I believe. I don't have any problems with LOL encodes - just from this new group, TCM. Usually, I use Virtualdub to extract the audio from the AVI file into a WAV then recombine the two in TMPGenc. However, my problem at the moment is that I'm not managing to extract the audio.
In Virtualdub, I select FULL PROCESSING MODE, then under conversion I'm selecting 44100HZ. When I go to save WAV it says that the encoding isn't possible and that I should check I have the correct codec. I've run GSpot which tells me I have 3 compatible codecs to read the file, and indeed I don't have any problems running the file on my PC. But Virtualdub doesn't seem to want to extract the audio itself.
ANY hints would be really appreciated. I'm totally stuck!
stephanV
Posted: Feb 18 2005, 10:45 AM
Forum rules forbid it to ask questions about warez or illegal downloads...
useful links:
TheAsylum
Posted: Feb 18 2005, 10:50 AM
I'm sorry, I didn't realise - my bad, I should have read the rules. Hopefully a mod will delete this post?
2 replies since Feb 18 2005, 10:44 AM Track this topic | Email this topic | Print this topic
