| Markus186 |
Posted: Nov 29 2002, 10:58 PM |
Is there a way to make V-Dub see the LSX-Mpeg v2.01 plugin codec? I have found this new version to be great but doing everything in Adobe premiere is a pain and slow going.
Anyhelp would be great. Thanks |
| TKSoft2000 |
| Posted: Dec 1 2002, 12:40 AM |
You can use the VirtualDub Frameserver to serve the videostream to the stand alone Version of LSX, or you can open the served AVI in Premiere and export it over LSX.
Regards TKS |
| Markus186 |
| Posted: Dec 1 2002, 02:15 AM |
Ok, But what I am wanting to do is Encode with LSX-Mpeg with V-Dub. I found that encoding and cropping in Premiere is very slow. So Basically I'm looking for a way to make The LSX-Mpeg plugin work with V-dub.
Thanks |
| drizztcanrender |
| Posted: Dec 5 2002, 03:23 PM |
Try Link2.It's a sort of avisynth kind of wrapper that might be able to do that.I don't remember the exact address right now but our friend google i'm sure it will help |
| TKSoft2000 |
| Posted: Dec 11 2002, 07:31 PM |
@drizztcanrender
The URL of Link2 is www.videotools.net
A very powerful frameserver!! Registering is no fault!
I always use this frameserver in Premiere to frameserve to TMPG or other Encoders...
Be careful with the DEMO-Version it is really slow because there is a framelimit per second, but the registered Version ist really fast!
Regards TKS
