| ezrider |
Posted: Apr 2 2003, 08:13 PM |
hello
i'm trying to encode a movie with subtitles, but i get the following message after trying to save it: "You are trying to compress with a hacked compression driver. This may cause VirtualDub to act or crash unexpectedly...." i tryed choosing differebt kindes of audio compression drivers, al resulting in the same message. my os is win xp pro, and i have the nimo5(build 8) codec pack fully installed. another odd thing is that i don't have any divx audio codecs listed in VirtualDub under "audio>compression"
how can i solve these problems??
thanx |
| ChristianHJW |
| Posted: Apr 2 2003, 11:09 PM |
1. Dont use the DivX Audio codec, it sucks ( hacked version of old WMA )
2. You can ignore this error message if you insist to use WMA, your movie will play fine anyway.
Search the internet for 'mp3' 'codec' , sometimes people make presents to other, maybe somebody will lend you a valid Fraunhofer MP3 installer ???
EDIT :
Hum, after reading your message again it seems i completely missed the point. The Nimo pack in fact should come with a MP3 codec. And you say DivX Audio is not even listed under 'audio' 'compression' ? Thats strange because the Nimo pack should install it, amongst others.
What is the source movie you are trying to work on ?
| ezrider |
| Posted: Apr 3 2003, 05:27 AM |
the source movie is "half baked" (does it matter ??) or did you mean the source file format > divx. anyway i understand the best way is to encode audio with an mp3 codec. i'll try this.. |
