Audio Problem, Audio Problem
jcduranf
Posted: Mar 12 2003, 05:08 AM
Hi.
When i open a AVI File, Virtualdub show me this message "VirtualDub has detected an improper VBR audio encoding in the source....." and when i try to view a preview of the movie, i can't hear the audio.
So, i try changing Audio from "Direct stream copy" to "Full processing mode", but when i try to get a preview of that, Virtualdub shown this message "No audio decompressor could be found to decompress the source format.".
The File Information for Audio Stream is:
Sampling Rate: 48000Hz
Channels: 2(Stereo)
Sample precision: 0-bit
Compression: Unknown (tag 0055)
Could somebody help me please?
Thanks
mikitow
Posted: Mar 12 2003, 06:26 PM
That´s because your audio stream is mp3.. and VirtualDub cannot deal with that.
First of all, you have to save the audio stream to uncompressed wav:
Open video file.
"Audio" -> "AVI audio"
"Audio" -> "Full processing mode"
"Audio" -> "Compression" -> "<No compression (PCM)>"
"File" -> "Save WAV..." -> (enter there wav file name)
Then, just went back to VirtualDub and do the follow:
"Audio" -> "WAV audio" -> (browse to needed wav file)
"Audio" -> "Compression" -> Choose compression you want
"File" -> "Save as AVI..."
Of course, doin´ that u´ll loose a little bit of quality of the audio stream.
jcduranf
Posted: Mar 16 2003, 03:12 AM
Thanks, but when i try with "Save WAV...", Virtualdub shown this message "No audio decompressor could be found to decompress the source format.".
mikitow
Posted: Mar 18 2003, 12:45 PM
OK.
Try using direct audio stream copy.
Open video file.
"Audio" -> "Direct Strem Copy"
Then rename the filename to xxxxx.mp3.
After that, decode the mp3 file using any program that handles mp3 format.. like goldwave or whatever do u want to use.
3 replies since Mar 12 2003, 05:08 AM Track this topic | Email this topic | Print this topic
