| falcon_fighter |
Posted: Mar 10 2003, 04:03 AM |
Does anyone know of a null codec, one that just takes the video, dumps it, and writes a blank output file or none at all, like for extracting AC3 out of a VOB file? It might have other uses, that was a bad example. But does it exist? |
| Posted: Mar 10 2003, 05:24 AM |
| QUOTE (falcon_fighter @ Mar 10 2003, 12:03 AM) | | It might have other uses ... |
Like what? TMPGEnc can demux the AC3 from a VOB file, and VirtualDub can demux the audio from an AVI file. So why do you need a null codec?
| Melkor |
| Posted: Mar 21 2003, 07:56 AM |
there is a null render for use in custom made graphs for graphedit... but you don't need to use it if you make a custom graph. you just don't connect anything to it.
if you a demuxing something strange (like pulling a subtitle track out of an avi) you can do that with graphedit, profided you have the filters to render it... |
