| AAL1947 |
| Posted: Mar 7 2003, 06:08 AM |
Have the following video and need the AC3 Codec so that I can re-encode the video. Need to convert the AC3 to WAV. Want to end up witha MPG file.
Help Please. Thanks in advance. Tried search for AC3 but found it confusing.
Info from TFO Codec Finder v1
Video Info:
Movie Name: C:\boa.txt Codec: DivX;-) Fast Bitrate: 813 Kbit/s Width: 360 Height: 240 Fps: 29.970
Audio Info:
Codec: AC3-Digital BitRate: Kbit/s (Rounded BitRate) Channels: 2 (Stereo) Sample Rate: 56,000 Hz
Miscellaneous
Size (MB): 531 MB Size (kB): 544,033 KB Size (real): 557,089,420 Length: 89 minutes, 11 seconds.
Date/Time Info Compiled: 3/7/2003, 1:00:48 AM
| ChristianHJW |
| Posted: Mar 7 2003, 08:13 AM |
There is no AC3 codec for Virtualdub, as it can only work with ACM codecs and there is no AC3.ACM .
You have to extract the audio stream using Virtualdub's 'save WAV' function and then load the AC3.wav into BeSweet or HeadAC3he ( www.doom9.org or www.everwicked.com ) to process it to PCM WAV ....
