Mp3 Compression Lost?, Need help restoring this?
chrisdv98
Posted: Mar 3 2003, 09:58 PM
I have recently bought a new computer and set up everything as i had it before - or so i thought.
I wish to re-encode a WAV file as an mp3 - but the bitrate options for mp3 compression in virtualdub only go up to 56k/s
Just wondered what i need to do or install to give me all of the options up to 128 and beyond.
Thanks
Chris
krage
Posted: Mar 4 2003, 07:42 AM
you have install the windows media player and he installs his own mp3 codec (trash). You must reinstall your mp3 codec.
Ciao
Gerold
chrisdv98
Posted: Mar 4 2003, 12:34 PM
i sort of gathered that could have been it, but where do i get the good mp3 codec from?
thanks
jcsston
Posted: Mar 5 2003, 02:56 PM
Matroska Dev
Use the Matroska file format
S_O
Posted: Mar 5 2003, 04:39 PM
Vdubmod Alpha Testing Team
youŽll find a codec that works fine, but to compress a wav to mp3 there is a better, faster and easier way: use lame
It will offer you much higher quality than the codec you find in the internet for VirtualDub.
More information, recommend settings & compiles:
http://www.hydrogenaudio.org/index.php?act...t=ST&f=15&t=203
Posted: Mar 5 2003, 06:04 PM
The LAME command line encoder is great, but the ACM version of LAME gave me all kinds of problems and I don't recommend using it for movies.
5 replies since Mar 3 2003, 09:58 PM Track this topic | Email this topic | Print this topic
