Messed Up Avis, Maybe mixed fps? trying to understand
David.Bucci
Posted: Feb 27 2003, 07:15 PM
Hey ... I have a video that is giving very quirky behavior ... DivX 5.02, PCM uncompressed audio. VD reports frame rate as 28.334 dry.gif
When I open it in VD alone, it will render up to the first keyframe (actually, 2nd ... I assume it starts on a keyframe), then the video freezes but audio continues on.
When I use AVISynth AVIFile(), it renders up to the first keyframe, then the video loops back to the first keyframe, and keeps doing that, rendering the first 27 frames repeatedly, while again the audio progresses on.
It plays fine in ZoomPlayer, WMP, so I tried DirectShowSource() ... produces an error that says AVISynth can't determine the frame rate. So I set the framerate in the DirectShowSource call, to 28.334 -- now I get no audio.
So I demux the audio, and add it back in, and it's way out of sync. Offsetting doesn't work, because the sync changes over time. Changing the frame rate (in AVISynth) allows me to match the length of the audio, but the sync drifts in and out. sad.gif wacko.gif
Any ideas? Is it possible that the different parts of the vid are meant to render at different frame rates? (does AVI support this?)
Thank you.
0 replies since Feb 27 2003, 07:15 PM Track this topic | Email this topic | Print this topic
