Flac On Virtualdub, Lossless compression
Celes
Posted: Sep 24 2012, 03:10 PM
I'm searching for best codecs to encode my videos.
After having see specifications of ALL codecs, it appears to be :
- Video : x264
- Audio : FLAC
- Container : MKV
Problem, it's impossible to use FLAC on VirtualDub.
The scenerules ask to use AAC instead (open-source, 42 channels, but lossy).
I want to know if there are a way to use a codec FLAC on virtualdub.
I actually use CoreFLAC ACM, which allows to encode somehow, not everytime, but wihich doesn't allow to decode.
Is there a way to read FLAC on VirtualDub ? A plugin, or something via Directshow ?
Is there a way to contact the CoreFLAC ACM team to help them to write the code ?
Thank you.
ale5000
Posted: Sep 24 2012, 06:03 PM
CoreFLAC ACM does also support decoding but it only work with few files.
Unfortunately CoreFLAC ACM is a bit abandoned.
New VirtualDub forum
Celes
Posted: Sep 26 2012, 03:14 PM
QUOTE (ale5000 @ Sep 24 2012, 06:03 PM)
Which files ? What are the specifications ?
I'll try to update that...
2 replies since Sep 24 2012, 03:10 PM Track this topic | Email this topic | Print this topic
