Missing Codec For Flv, intsalled but not working
picaso
Posted: Jul 26 2011, 11:31 AM
I installed the driver from here
http://home.comcast.net/~fcchandler/Plugin.../FLV/index.html
,but when I tried to load the video.flv , it said "missing codec."
I never had this problem for other video such as wmv , or vob , so why is .flv making such problems ?
Placio74
Posted: Jul 26 2011, 11:56 AM
VideoAudio
QUOTE (picaso @ Jul 26 2011, 01:31 PM)
Because in FLV video is encoded in other formats - FLV1/H.263 or FLV4/VP6F or H.264/AVC - and you do not have installed VfW codecs for them.
You can use ffdshow VfW to decode these vid's (go to ffdshow video encoder config and Decoder tab). As well as for H.264/AVC can use x264vfw.
Also, to decode AAC audio you need AAC ACM Codec.
picaso
Posted: Jul 26 2011, 12:14 PM
QUOTE (Placio74 @ Jul 26 2011, 11:56 AM)
I have ffdshow installed , but not sure if I set it correctly,
please can you take a look at my screen shot ? -
here-
http://w1funurl.webs.com/flv-error.JPG
So once its set correctly , virtualdub should be able to play it , right ?
Ok , I found it , you were right , it was disabled !! , I enabled it now , here -
http://w1funurl.webs.com/ffdshow-codec.JPG
2 replies since Jul 26 2011, 11:31 AM Track this topic | Email this topic | Print this topic
