| JaliM |
| Posted: Mar 8 2011, 03:23 PM |
Does anyone know a software in which I can set up / configure ACM and/or VFW 64-bit installed codecs?
I know AnalogX ACMProperties which can configure 32-bit ACM codecs, but it doesn't detect installed 64-bit ACM codecs (Is a 32-bit only software)
I know AnalogX DXMan, or Radlight FilterManager which can configure 32-bit DirectShow filters, but no 64-bit support.
I Know VCSwap which can enable/disable VFW 32-bit codecs.
I Know Codec Toolbox RS but VFW/ACM support is incomplete, in both 32 and 64 bits modes.
I Know NirSoft InstalledCodec which can enable/disable BOTH 32/64 bit ACM, VFW and DirectShow filters but is not possible to configure any filter properties... Please help |
| ale5000 |
| Posted: Mar 8 2011, 08:40 PM |
Currently: For 32/64 bit VFW codecs you can configure them directly from inside VirtualDub 32/64 bit. For 64 bit ACM codecs you should be able to access their configuration through control panel. For 32 bit ACM codecs you could use a software.
In the future the softwares will become more complete.
| JaliM |
| Posted: Mar 8 2011, 11:06 PM |
I use Win7 64-bit, What control panel are you talking about, Windows one? I can't find anything about ACM codecs .... |
| ale5000 |
| Posted: Mar 8 2011, 11:15 PM |
On Win XP x64 it is something like this: Control panel => Sounds and Audio Devices => Hardware => Audio codecs => Properties => Properties
On Win 7 64-bit it could be similar, I can't try it now.
| JaliM |
| Posted: Mar 9 2011, 07:40 AM |
I know where audio codec prioperties are in windows XP but I cannot find anything similar coniguration panel in Win 7. Does Anyone know where they are? |
