| Posted: Dec 17 2011, 09:23 PM |
The only question I have is, when you double-click a .bat file does it launch in a 32-bit process or a 64-bit process? Because if it is a 32-bit process, I think it will perceive the PROCESSOR_ARCHITECTURE environment variable to be X86.
| Posted: Dec 17 2011, 09:50 PM |
.bat's launch in the native cmd environment, running as a 64 or 32 bit process (you can check your own, by opening a cmd prompt, and just typing 'set' without quotes) So, on my amd cpu, it shows as AMD64
Personally, I'd use InnoSetup instead of .bat files though and have a proper installer That's what I used for the LameACM installer in my sig
| ale5000 |
| Posted: Dec 17 2011, 10:01 PM |
Personally I like to be able to choose if install the 32-bit version, the 64-bit version of both versions of the codec. Also uninstall batches aren't necessary, since it can be done from "Add or Remove Programs".
| Posted: Dec 17 2011, 10:18 PM |
There's no reason an installer can't offer both if it's installed in an x64 environment, mine does, with 2 checkboxes
Saves the average user headaches with running .bat's as admin etc
| ale5000 |
| Posted: Dec 17 2011, 10:55 PM |
@dloneranger: I was talking only about the bat files of Spider-Mann.
| Posted: Dec 17 2011, 11:32 PM |
| QUOTE | | @dloneranger: I was talking only about the bat files of Spider-Mann. |
Ah, gotcha
| ale5000 |
| Posted: Dec 18 2011, 01:41 AM |
Edit 2: Updated files => http://www.multiupload.com/NV6QRNZEMJ
Changes: - Reduced the number of .bat files from 3 to 2 - Added the note of "Run as administrator" in .bat files for users that don't read the readme - Minor changes
Tested on Windows XP, Windows XP x64 and Windows 7 64-bit.
| ale5000 |
| Posted: Dec 18 2011, 04:07 AM |
In the case you consider adding encoding support, maybe this library can help: http://tipok.org.ua/node/17
| Posted: Dec 18 2011, 04:32 AM |
| QUOTE (ale5000 @ Dec 6 2011, 11:56 AM) | Sample file (706D - Hatsune Miku.avi - 4.73 MB): http://www.multiupload.com/VQC224UJ3H
This is another sample of 706D audio but this is more compliant to AVI specs. On my pc it play in DirectShow players using CoreAVC for video and ffdshow-tryout for audio.
Could you give a look and see if it is easier to support, please? |
I have been playing with this one, but it doesn't seem to be as compliant as you think. I've implemented support for tag 0x706D but your file will not play in VirtualDub due to errors from faad2. I think it is muxed in a strange way; for one thing the audio stream starts with a whole bunch of zeroes. I'm no expert on AAC bitstreams but I know at least that much ain't right.
The video won't play either in VirtualDub; ffdshow-tryouts just gives me a black screen. Unless I am running it in a debugger, in which case it gives me pink/purple garbage. Weird...
MPlayer plays it just fine.
Anyway 0x706D support will be in the next version, but I want it to be optional. Therefore I need to make the registry keys more user-friendly since the Windows XP Control Panel is pretty much useless for configuration.
I will go ahead and update the .bat files too.
As for AAC encoding, that is a major upgrade. I would like to do it, but methinks it won't be any time soon. For a long time AC3ACM did not have the ability to encode, and I remember it was something of a nightmare getting that to work.
| ale5000 |
| Posted: Dec 18 2011, 12:33 PM |
| QUOTE (fccHandler @ Dec 18 2011, 05:32 AM) | | Anyway 0x706D support will be in the next version, but I want it to be optional. Therefore I need to make the registry keys more user-friendly since the Windows XP Control Panel is pretty much useless for configuration. |
VirtualDub 1.10.1 test versions allow to access ACM codec configuration directly from inside VirtualDub (Audio => Compression => Configure). Also you can export the "Configure" function in the dll so it can be run like x264vfw: rundll32.exe x264vfw.dll,Configure
| ale5000 |
| Posted: Dec 19 2011, 05:07 PM |
| QUOTE (fccHandler @ Dec 18 2011, 05:32 AM) | | The video won't play either in VirtualDub; ffdshow-tryouts just gives me a black screen. Unless I am running it in a debugger, in which case it gives me pink/purple garbage. Weird... | From my tests the video play in VirtualDub using x264vfw (not with ffdshow-tryouts VFW), and it play in DirectShow players with CoreAVC for video and ffdshow-tryouts for audio but it doesn't play when using ffdshow-tryouts for both video and audio.
| Posted: Dec 22 2011, 04:08 AM |
I found out today that the installers (.inf and .bat) for AC3ACM were completely broken on Windows 98. I had to make several changes to the 32-bit installer to get it to work properly on both 98 and XP. I don't know how these changes might impact Windows Vista and later...
I need to check AACACM as well before releasing a new version, because it will probably need the same changes. Stay tuned.
| Posted: Jul 21 2012, 05:24 PM |
I've uploaded new builds of AACACM 1.9 and AC3ACM 2.2 to satisfy a request for Windows 95 and Windows NT support:
http://fcchandler.home.comcast.net/AACACM
http://fcchandler.home.comcast.net/AC3ACM
(For the record, applications compiled with Visual Studio 2005 will not run on these old operating systems.)
I didn't do anything with the codecs (except recompile), but AACACM contains some old test code from when I was trying to add support for tag 0x706D. I don't know whether that part actually works, but it doesn't seem to have broken anything so I left it in.
| wsm-9t6 |
| Posted: Aug 1 2012, 02:54 PM |
First of all, apologies if this question has been already posted and answered, but...
well, it's not a problem really, but I'd like to know why the AAC ACM appears in the WMA "flavor list" of both WmNicEnc.exe and wav2wma.exe |
