| Manwel |
| Posted: Feb 16 2003, 09:34 AM |
yo, after opening a file i get the boring message : "couldn't locate decompressor for format Dx50(unknown),virtual dub requires a video for windows compatible codec................suitable" . Recently install codec divx 5.03 , need something more or less?
thanks |
| ChristianHJW |
| Posted: Feb 16 2003, 11:59 AM |
Use the 'search' function here ( see on the top ) on the keywords 'decompressor' and 'dx50' ... there were a couple of other threads on this before IIRC ...
| Gnerma |
| Posted: Mar 14 2003, 05:47 AM |
| QUOTE (ChristianHJW @ Feb 16 2003, 05:59 AM) | | Use the 'search' function here ( see on the top ) on the keywords 'decompressor' and 'dx50' ... there were a couple of other threads on this before IIRC ... |
Hi ChristianHJW, sorry about the resurrection but this was the only thread that came up with a search of 'dx50' and the search found nothing when looking for 'dx50 decompressor'. I am having the same problem of course. TMPGenc can not open the file either so I suspect it is a codec problem. Could you direct me to the afformentioned threads? thx |
| ChristianHJW |
| Posted: Mar 14 2003, 11:14 AM |
| QUOTE (Gnerma @ Mar 14 2003, 07:47 AM) | | Could you direct me to the afformentioned threads? thx |
You obviusly forgot to search in all forums, and to allow posts being displayed being elder than 30 days. Here is the performed search on 'dx50' :
http://virtualdub.everwicked.com/index.php...6&highlite=dx50
This thread will contain any info you need :
http://virtualdub.everwicked.com/index.php...b5686c897d5d107
If this fails try this :
ok ?
