Vfw Or Video Codec Settings, about FFDShow
avirtualfall
Posted: Nov 30 2010, 05:15 AM
Among these two which menu has priority over the other.
FfdShow->VFW Settings->Codec
FfdShow->Video Settings->Codec
In following examples which one takes effect, and which one is 'required' for VD to edit WMV files.
case 1) //which one takes effect among these two
VFW Settings->WMV9 = disabled
Video Settings->WMV9 = Wmv9 or Libcodec
case 2) //which one takes effect among these two
VFW Settings->WMV9 = Wmv9 or Libcodec
Video Settings->WMV9 = disabled
Thanks in Advance
Ramesh
Placio74
Posted: Nov 30 2010, 08:28 AM
VideoAudio
Shortcuts created by current version of ffdshow installer it's: VFW configuration and Video decoder configuration (also few other).
If You use WMV input plugin, go to VFW configuration (and Decoder tab).
This plugin uses VfW codecs (like VirtualDub) and does not use DirectShow.
If You use DirectShow import driver, go to Video decoder configuration (it's ffdshow DirectShow filter config).
But usually it is not necessary, because Windows system contain own DirectShow WMV decoders.
No priority between this (VfW/DirectShow), because it's different 'frameworks'.
VirtualDub natively does not support ASF container (normally used for WMA/WMV). However can use (mentioned earlier) input/import plugins.
1 replies since Nov 30 2010, 05:15 AM Track this topic | Email this topic | Print this topic
