| Athenatius |
| Posted: Aug 19 2010, 02:41 PM |
I'm trying to compress a short AVI after I took the logo away(LogoAway 4.01). I choose for the Xvid MPEG-4 Codec and afther that I click 'save as Avi'. But I'm receiving an error: "cannot start video compression: an unknown error occured(may be corrupt data). (errorcode -100)
I've got K-Lite Mega Codec Pack installed.
Do I still miss a codec?
Thanks! |
| Posted: Aug 19 2010, 02:59 PM |
Usual reasons include
Width not a multiple of 4 Height not a multiple of 4 Fps too high for the selected profile in the codec
| Athenatius |
| Posted: Aug 19 2010, 03:18 PM |
I'm sorry but I don't have a clue where you're talking about... I'm not that familiar with VirtualDub or compressing files. Maybe you could be more specific?
What exactly is wrong? |
| Posted: Aug 19 2010, 03:25 PM |
Check the video source File menu->File Information
You'll see the width and height and fps of the video there
To recompress, most codecs like xvid need the width and height to be a multiple of 4 If it's not then it won't compress it and you'll get an error
If the video doesn't have a height or width that is a multiple of 4, then you can either 1)add a null filter and crop off the excess pixels to get the right size or 2)add a resize filter and set the width/height to the nearest multiple of 4
The help file is useful, and so is the search button on the forum Youtube also has 'walkthrough' videos
| Athenatius |
| Posted: Aug 19 2010, 04:12 PM |
Thanks for the information, it was much more clear for me.
It worked by using the resize filter. But maybe the quality could be a bit better.
So I want to do it all over again with VirtualDub. The sourcefile of this small video is a flv. I used Total Video Converter to convert it to MPEG4V2 Avi normal quality. XVID Normal quality didn't work because of the same problem you were talking about before.
My question is: to what should I convert this flv-file to use it in VirtualD? What is the best quality? Maybe I shouldn't use Total Video Converter? |
