| WookieSM |
Posted: Feb 10 2003, 01:50 PM |
yo peeps ive been useing vdub for 6months now and have just started to use it to capure. when i go to edit my capture (encoded in DivX502 pro)the name of the compression is angelpotion not DivX as i thought but now i cant edit them in vdub because it says i need a (VFW)(video for windows)decompresser can any1 help me |
| Kippesoep |
| Posted: Feb 10 2003, 07:58 PM |
AngelPotion is a bad version of an illegal codec. Remove that codec and install DivX 5.02 again (or better yet: download the recently released 5.03). Make sure you set DivX5 to handle DivX3 content as well (so it will take over the appropriate FOURCC handlers).
The method used to remove a codec depends on your Windows version. If you use XP, go to "Control Panel", choose "Sounds and Audio Devices", "Hardware", "Video Codecs", "Properties". There you'll get a list of codecs and can remove the ones you don't need/want. In Windows 9x, go to "Control Panel", choose "Multimedia", "Devices", "Video Compression Codecs", choose the codec to remove, click "Properties", then "Remove".
| ChristianHJW |
| Posted: Feb 11 2003, 09:51 AM |
Ahhh !! crappy angelpotion has striked again !! Somebody handle a gun to the poor guy, his PC is inevitably lost forever now ....
| WookieSM |
Posted: Feb 20 2003, 12:31 AM |
yo guys cheers you are wounderull (yuuk) hehe thanks |
