| decoydeniro |
| Posted: Feb 8 2003, 11:01 PM |
Problem: No Audio
Error Message: The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format.
Using AVIcodec, I know that the codec needed is AC3 DVM... however I've looked all over the net and only found AC3 filters... with the filter I can view and hear the AVI using media players: ViPlay, and Sasami2k, and WM 6.4, however still no audio in VDub... I can't even select AC3 as a possible codec selection in VDub...
The movie plays crisp in clean in Vdub and is not watermarked, but without sound... in all of my media players, the movie is watermarked and plays sound...
can anyone help me out with audio in Vdub..??
Thanks a bunch...
| crash |
Posted: Feb 15 2003, 01:29 PM |
OK I HAVE THE AC3 CODEC I DOWN FROM THIS SITE ....SO WHERE DOES IT GO IN WINDOWS SO IT LOADS ??? RUNNIN WINXP PRO ...help !! thanks!! |
| valja |
| Posted: Feb 15 2003, 02:24 PM |
Hi guys! Please use search function and search for "AC3", also take a look to "Newbie questions" section.
Nobody wants to answer the same questions again and again. |
