Smeared Video Using Fcchandler's Wmv Plugin
Gibfish
Posted: Mar 8 2009, 08:11 PM
I've just been trying to transcode a .wmv into an .avi (at a more sensible data rate), but I found the resulting DivX .avi was smeared - only becoming clear at each keyframe (can't remember the exact name for them).
I thought this was a DivX issue so I altered settings etc, but things didn't improve.
I then checked the .wmv as opened within VirtualDub and saw that the smearing was occuring during the decode of the .wmv. However, the .wmv does play correctly in Windows Media Player and VLC.
I'm using v1.7 of the WMV plugin, in versions 1.8.6, 1.8.8 and 1.9.0 of VirtualDub.
Is this a known bug with the plugin, and is there a new version planned?
Placio74
Posted: Mar 8 2009, 09:32 PM
VideoAudio
What's used video decoder?
Gibfish
Posted: Mar 8 2009, 10:41 PM
I was using Fcchandler's Wmv plugin to open the video into VirtualDub, and the K-Lite codec package for watching it through Windows Media Player.
Placio74
Posted: Mar 8 2009, 11:48 PM
VideoAudio
Look at File information, what is used video decompressor...
It's Microsoft Windows Media Video 9 or ffdshow Video Codec or some other?
WMV input plugin not decode A/V. It just add support for input ASF container. For decoding A/V need required codecs installed in system (VfW and ACM, but not DirectShow filters).
And what if you use DirectShow input driver?
BTW
K-Lite not contain Windows Media codecs.
Gibfish
Posted: Mar 9 2009, 10:04 AM
Sorry, my mistake - it says Microsoft Windows Media Video 9 (WMV3). How do I use the DirectShow input driver?
Placio74
Posted: Mar 9 2009, 12:04 PM
VideoAudio
QUOTE (Gibfish @ Mar 9 2009, 12:04 PM)
http://www.virtualdub.org/beta/DShowInputD...tDriver-0.5.zip
Download and unpack to plugins subfolder.
Or download and install VirtualDub Plugins Pack.
When open video file change file types to DirectShow input filter.
Gibfish
Posted: Mar 9 2009, 05:46 PM
Thanks - using the DirectShow input filter, it's decoding properly now.
6 replies since Mar 8 2009, 08:11 PM Track this topic | Email this topic | Print this topic
