Couldn't Locate Decompressor For Format 'dx 50'
Cass
Posted: Jan 15 2003, 04:47 AM
Hi guys
This is my first post,got couple movies and wanted to do my SVCD as allways.This movie creates problem for me.
The Error is:
Virtual Dub requires a Video for Windows (VFW)compatible codec to decompress video.Direct Show codecs,such as those used by Windows Media Player,are not sutable.
Can anybody help me with this one,Please.
Neo Neko
Posted: Jan 15 2003, 05:14 AM
VirtualdubMod Alpha tester
Got Divx5 installed?
Cass
Posted: Jan 15 2003, 05:29 AM
Yes,got one.
Mongobolk
Posted: Jan 16 2003, 06:49 PM
You can install every divx codec you want but it doesn't run under xp. don't know why but it sucks real hard, cause i mostly use the divx codec.
Cass
Posted: Jan 19 2003, 09:43 AM
Thank you .I was trying so hard to fix the problem but without any luck.If anybody knows more about possible cure for it ,please post it for me.
ChristianHJW
Posted: Jan 19 2003, 12:07 PM
Why do you need Virtualdub to create S-VCDs ? Use TMPEGencoder from www.doom9.org ...
Cass
Posted: Jan 22 2003, 05:10 AM
Because I need audio for my movies.If you use TMPEGnc ,how do you get audio with picture.Talking about Super VCD.
Cerberus
Posted: Jan 24 2003, 08:19 AM
Neo Neko
Posted: Jan 24 2003, 09:00 PM
QUOTE (Mongobolk @ Jan 16 2003, 12:49 PM)
Divx 5 works fine under XP SP1 here with Virtualdub. Divx5's main encoder/decoder module should be VFW. The only directshow component is one of the decoders. So I am at a bit of a loss as to why it is complaining about VFW decoders. As always a complete uninstall and re-install is recomended.
8 replies since Jan 15 2003, 04:47 AM Track this topic | Email this topic | Print this topic
