| vidfan |
| Posted: Aug 3 2007, 09:41 PM |
I'm new to the forum and new to Vista as a result of a new PC purchase. For the past 3 yrs, I'd been happily using VirtualDib with Windows 2000 until the motherboard died. With Vista, I no longer have a choice of the MPEG4 options for compression when I use VDub, and end up with larger files than the source file.
I saw the July 3 post in the Codec Discussion and am wondering if there are any new developments since then.
I'm minimally computer-literate and ask that you keep that in mind in your response.
Any help would be greatly appreciated. |
| gigp-com |
| Posted: Aug 11 2007, 09:37 PM |
There are several places to download the codex. Ask this guy for a download info@upinit.com he is my brother and has them all. Tell him Astrea sent you. |
| i4004 |
| Posted: Aug 12 2007, 12:41 PM |
i've heard vfw works under vista, so go here http://www.free-codecs.com/ and dload codecs you want
mpeg4 is usually xvid or divx
do not dload and install codec packs...
