Sound Problem!, Sound problem with 2 big files in xvid!!
cyklop
Posted: Dec 18 2002, 12:08 PM
I have the same problem as sk1968 had!!But I cannot resolve it using suggections made to him!! It's typical for movies that are in two big files of 700MB ie. Die Another Day. I can easily view it on computer but when I want to transform it to SVCD the sound is not detected both in Virtual Dub and TMPG Enc!!
I cannot save the sound to wav file because it gives me:
"Check that the sampling rate and the channel count of the input match thoose of the requested format."
I'm also writing file info:
Sampling rate 48000 Hz
Chanels 2(Stereo)
Sample precision 0-bit
Compression unknown(Tag 2000)
Preload skew 1536 samples (0,03s)
# of frames 62756
min/avg/max/total frame size 845/1536/1536(94134k)
I also tried to use AC3 Fix ver0.3 but I don't now how to use it. I wrote ac3fix filename.avi filename.ac3 he created this file ac3 but also VD and TMPG don't recognize them!!
I also have hex editor always in read only mode!!
I have VD ver 1.4.13
PLEASE HELP!!!
cyklop
Posted: Dec 19 2002, 08:58 AM
Ok I manage to get throught this problem using instructions that have been made to sk1968!
Thanks
1 replies since Dec 18 2002, 12:08 PM Track this topic | Email this topic | Print this topic
