| flipyer |
| Posted: Aug 28 2002, 06:00 PM |
I keep getting a program failure due to access violation and lots of code i dont understand, this happens after i click save avi for the second part of a divx movie almost immediatley can anyone help because its doing it all the time and i dont know any other programs or how to use them
please help
thanks |
| BaronVlad |
| Posted: Aug 28 2002, 06:08 PM |
Terrorhörnchen
Can you please tell us exactly what you are trying ? What source do you have, which compression do you try (audio and video)...which other settings (filters...)
Thanks
| SillKotscha |
| Posted: Aug 29 2002, 10:01 AM |
smart Moderator
| QUOTE (flipyer @ Aug 28 2002, 08:00 PM) | | I keep getting a program failure due to access violation and lots of code i dont understand |
are you sure, that your cropping region is (x-factor) is divisible by 4 ?!!...
| flipyer |
| Posted: Aug 29 2002, 05:37 PM |
yes sorry im using direct stream copy from an avi source and im trying to split it in two the first split is fine but as soon as i try the second i get a a program failure just let me know if theres anything else you need to know |
| ChristianHJW |
| Posted: Aug 29 2002, 07:26 PM |
..are you sure its an AVI and not a renamed Ogg ?
| flipyer |
| Posted: Sep 1 2002, 02:57 PM |
i dont know what ogg is it is s file downloaded from grokster .avi on the end. HOW CAN I TELL WHQAT IT IS DO YOU KNOW????????? |
| Asmordean |
| Posted: Sep 1 2002, 03:30 PM |
What filters are in use? |
