| electricraven |
| Posted: Apr 10 2012, 01:01 PM |
Dears, in my installed VD (see below!) is no opportunity for audio! In the menue bar there is: File, Edit, Video, Streams, Options, Tools and Help - but no Audio! does it need a plugin, or was on installation running something steep? Probably this could be the reason, why all rendered movies runs with Audio/Video asynchronous?? (because nothing is to adjust?) could somebody help? would be great! thx!
OS: Win XP SP 3, HP tc4400 VD: 1.5.10.2 (build 2540/release) what else?? |
| Posted: Apr 10 2012, 01:31 PM |
No, you didn't install Virtualdub What you have is virtualdubmod - an old modified version of virtualdub
In that version, the audio is all handled from the 'streams' menu
| electricraven |
| Posted: Apr 10 2012, 02:38 PM |
and is it possible to handle the audio in that way, that results dont be asynchronous? |
| electricraven |
| Posted: Apr 10 2012, 02:52 PM |
by the way, if i install VirtualDub (1.9.x), do i have to uninstall the virtualdub-mod? or can i leave it stay?? |
| electricraven |
| Posted: Apr 10 2012, 02:58 PM |
Hello, after downloading & installing VD 1.9.11 i get this error, when i want to open a file:
MPEG Import FIlter: invalid pack at position 3: marker bit not set; possibly MPEG-2 Stream
do i have to load some plugins? and if yes: how???? and which, if i wants to open files from TV-records??? (MPG2?) could someone help in this virtualdjungle? thx |
