| Sikboy1029 |
| Posted: Mar 26 2012, 11:54 AM |
Recently upgraded to bluray so when editing files the crop window more than fills the screen and I can't adjust all sides because they are out of view due to my monitor only being 1920x1080, is there a way to resize the crop window? I should note this is in virtualdubmod so maybe you can't help me with this. |
| Abrazo |
| Posted: Mar 26 2012, 07:22 PM |
I had a little look at VirtualDubMod 1.5.10 (don't know it there are more recent versions to find), and I can indeed confirm that it is not possible to reach all borders in case of a 1920x1080 pixel video.
If you have no particular reason to use VirtualDubMod, than why don't you give it a try with the real VirtualDub ?
You can use the stable version 1.9.11 of VirtualDub: http://sourceforge.net/projects/virtualdub...11.zip/download or use the prerelease version 1.10.2-test5: http://www.virtualdub.org/beta/VirtualDub-....10.2-test5.zip
In these both versions the resize window is limited to the maximum resolution of your monitor, so it will not exceed the borders and you will have the possibility to "crop" all sides. |
