Virtualdub 1.9 32 Bit, Installing Virtualdub in Windows 7
Gerald Sr.
Posted: Feb 10 2012, 03:17 AM
I've been confused for a couple of years on how to install Virualdub. I extracted Virtualdub 1.9 and there were 11 files. I highlighted all of the files and send them to program files on my computer, but when I check the Program files, nothing was there. I'm also having a hard time installing Neat Video into Virtualdub. Can someone please take the time and explain how to install Virtualdub my computer and Neat Video plugin into Virtualdub. Thank you.
Placio74
Posted: Feb 10 2012, 08:23 AM
VideoAudio
Just unpack archive to custom folder - for example C:\VirtualDub
and if you need, make shortcut to VirtualDub.exe
"Neat Video for VirtualDub" ask (last installation dialog before install) for location VirtualDub plugins folder where to copy plugin. Use Browse... button and select folder where you 'installed' VirtualDub and subfolder plugins - for example C:\VirtualDub\plugins
Even if you make a mistake, can copy plugin from "Neat Video for VirtualDub" folder (also is possible to extract plugin from installer).
1 replies since Feb 10 2012, 03:17 AM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
