| AEN007 |
| Posted: Dec 30 2011, 11:44 PM |
31December2011
Greetings.
Is there any way to dub different sources (e.g., 1 mpeg-2 file & 1 Xvid/mpeg-4 avi) to be able to use File Append avi segment and join them after dubbing? |
| Abrazo |
| Posted: Jan 1 2012, 09:33 AM |
This should be possible if you first dub/convert both files with the same audio- and video-codec, and (also important) the same bitrate (f.i. 128k Bit/sec) and sampling rate (f.i. 44.100 Hz) for audio and the same frame rate (f.i. 25 fps) for video.
For audio you should best choose for "No compression (PCM)" in the first step (= the creation of the separate files). This should avoid problems with audio synchronisation in the second step (= join).
Once you join the two resulting files, you can choose an audio-compression codec (f.i. "MPEG Layer-3"). |
| malky |
| Posted: Jan 1 2012, 01:47 PM |
The files can be joined using AviSynth. Here's a sample of an avi joined to an mpeg. Files must be same resolution and framerate etc. Sample: http://www.filesavr.com/9EM42ZXF0LY64I0 I added borders to the AVI to make it the same resolution as the mpeg. |
| AEN007 |
| Posted: Jan 4 2012, 01:02 PM |
4January2012
Greetings.
I have used "Method 1" in the past - but not always successfully it seems to me. I would be interested to see the aviSynth script for Method 2.
Yesterday Method 1 did not work for me. I guess maybe because I did 1 output file with Multipass Fast Recompress and the other with Multipass Full processing to add some filter/effects? It seems to me I have also had problems in the past appending outputs from flv files to outputs from non-flv files ... |
| malky |
| Posted: Jan 4 2012, 07:01 PM |
I'll just post the notes I made when I was doing it - I tend to forget steps. This could be done using a single script, but I like to verify each clip before joining and I find big scripts confusing. Sometimes AviSynth complains about fps, so ChangeFPS may have to be included even when it seems it's not required. Scripts use the .avs extension. This is joining a VOB clip and an AVI - good luck.
Collect all video source files and .avs scripts to a job folder on the desktop.
For mpeg files, download DGIndex. Copy DGDecode.dll from the DGIndex folder to the AviSynth Plugin folder. Run DGIndex and load the mpeg file. Select the audio track and output method (wav) 'Save project and demux video' - save the output to the job folder.
Create a script in Notepad and save as clip1.avs to the job folder.
| CODE | LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\DGDecode.dll") #v=MPEG2Source("t.d2v") #a=wavsource("t T80 2_0ch 192Kbps 48KHz.wav") MPEG2Source("t.d2v").info() #clip1=audiodub(v, a) #return clip1
Drag/Open the script into VirtualDub. Line 4 with the info() generates file information. Note the ColourSpace YV12 Resolution 720 x 480 FPS 29.97 Yours may be different. Exit VirtualDub.
Remove the comment # from lines 2,3,5,6 and add the comment # to line 4. Line 2 opens the .d2v information file for the video Line 3 note that the source audio is 48000. Line 5 joins the video and audio Drag the script back into VirtualDub and verify the sync is good. Exit VirtualDub.
Assume the second file is an AVI;this is the script, clip2.avs Open the script in VirtualDub.
| CODE | #v=changefps(avisource("clip.avi"),30000,1001).AddBorders(72,80,72,80) #a=avisource("clip.avi") #audiodub(v, a) avisource("clip.avi") info() |
The info told me that the fps=25, resolution is 576 x 320. This doesn't match the mpeg clip1, so they have to change. Colour space and audio are the same. Remove the comment # from lines 1,2,3 and add the comment # to lines 4,5. Line 1 changes the fps to 29.97 and adds a black border to make it 720 x 480. Drag the script into VirtualDub and note that it syncs.
To join the clips, create a new script and save with a new name, joinedclips.avs.
| CODE | a=avisource("clip1.avs") b=AVISource("clip2.avs") a++b
