Windows 7 Avisynth And Virtualdub.
malky
Posted: Sep 28 2010, 07:02 PM
A new install of Windows 7 64 bit.
Running 32 bit VirtualDub.
I cannot get VirtualDub to open an AviSynth script.
Tried a simple script "version()"
The same script loads and plays using Windows Media Player - but not Media Player Classic - (thus I assume AviSynth installed ok) but VirtualDub ignores it.
Task Manager is required to shut down the now non responding VirtualDub.
Posted: Sep 28 2010, 07:19 PM
Did you install the 32 bit version of avisynth ?
If it's playing in wmp, it sounds like you've installed the x64 version
malky
Posted: Sep 28 2010, 07:38 PM
It's version 2.5.8
I installed it directly then uninstalled and let AutoGK install it.
I also tried the latest Alpha and the result was the same.
Posted: Sep 28 2010, 08:04 PM
Can you post a screenshot if you load the .avs into Graphedit (32bit version) - or freeware GraphStudio http://blog.monogram.sk/janos/tools/monogr...am-graphstudio/
It should look like
malky
Posted: Sep 29 2010, 12:42 AM
Thank you for responding.
I removed everything from the plugins folder in the new Win 7 pc and AviSynth worked on VirtualDub and MPC.
I then added plugins until I found bass.dll that caused the virtualDub problem and an .avs file that affected MPC.
I had moved the entire contents of the plugins folder from my XP pc to the new one.
Posted: Sep 29 2010, 01:06 AM
;-) Sometimes half the battle is just knowing that it does/should work
5 replies since Sep 28 2010, 07:02 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
